240d primary fuel filter
Status
Not open for further replies.
byronspenc
New Registration
Can i use any cheap plastic see-thru filter? Also, where is the bleed screw for priming the fuel system?
Byron
njpumphrey
Abingdon
Yes, I think any see through filter will do the job. They are only about 40p from ECP. There is a piston to prime the system that has a black screw top a couple of cm in diameter. You unscrew this and then you can pull it up and down. It is pretty close to the main fuel filter.
Status
