250D with a fuel leak
veggy tastic
guildford
Hello people!!
im new to here as i have just been given a 250D automatic. after driving it for a while on derv i noticed that there is a fuel leak coming from the fuel pump. there is a slight weep coming from number 1 high pressure valve on the pump but there is so much down the side of the block that i am thinking it is something else like the stop solenoid?? since running it on veg oil it has got slightly worse??
anyone had this problem or does anyone know what i can do to fix this.
i am doing a £100 banger rally for charity to croatia in it in september and would really like to get it fixed before i head off so if anyone has any info please let me know.
many thanks
Veggy:D
wireman
lancashire
Clean it up, use gunk with a brush and then hose it clean, this will allow you to determine the actual source of the leak. Chalk dust or talc makes a good indicator for finding the actual point of leakage, just sprinkle it on liberaly.
For any dismantling of pump parts I would leave it alone and use a decent diesel bloke.
Your stop "soleniod" is a vacuum capsule atop the main body of the pump, it would only leak engine oil, and then only if its two securing bolts were loose.
V
veggy tastic
guildford
great!! thanks for that!! i have the day off on friday so i will have a blast at it.
when you say 'diesel block' do you mean something i add to the fuel??
mebobster
now that made me smile!!! i think wireman meant diesel BLOKE! meaning fellow or chap. have fun!
FIBAMAN
TYNESIDE
C180,C180,E300TURBO DIESEL
do you know anyone else who wants to give away a 250D?
V
veggy tastic
guildford
ah yes, me too once i read what i wrote!! HAHA What a tool i am!!
did'nt get the chance to do anything about it yet, but it still runs fine on veg and kerosine with a little engine oil
V
veggy tastic
guildford
well i cleaned the engine up with lots of break cleaner from work and fired her up. i found that it was coming from the first pressure valve on the diesel pump. after reading Parrots article on changing hie crush washers and rubber seals i am going to give it a go as it looks easy. i fiddle around with F3 cars all day and build gearboxes ect so i cant imagine it will be too challenging.
thanks for your responses above.:cool:
