smanderson117
- Jul 24, 2023
- W209 CLK270 CDI & W203 C220 CDI
Hello all, as title says I am about to lose it with my CLK 270 CDI om612 (2005). Backstory:
I had intermittent cutting out when giving it some and code P0251 injection pump metering control. It would cut out but a restart would fix it and clear code and off I went. Did this for 2 months until I got stranded on the motorway as car would restart but any load would kill it again. Changed fuel pressure regulator (theres a regulator/valve at the back end of the rail and a sensor at front of the rail and all seemed fine, easy fix I thought! It then started developing same symptoms again and also cranking was starting to take a while, especially when the car is warm. It still cuts out but it seems to be when you're foot the floor gunning it and only when it gets above 3.4/4k so when the car is really under load consistently.
In an effort to fix this I have loaded up the parts cannon and have since done/changed:
High pressure fuel pump for remanufactured unit with warranty
Leak off test which seemed ok (picture below) or within tolerance anyway (performed on hot engine until 1 tube became full)
Changed all low pressure fuel lines (fuel filter to LP pump, LP pump to HPFP, HPFP to the fuel rail at pressure regulator/valve end)
Unrelated: had black death on cylinder 5 so changed injector seals for the thicker honda ones and cleaned seats up real well etc with correct tools, slight cutting where needed
I can now see what seems to be air in the brand new fuel lines between filter and LP pump and LP pump to HPFP (HPFP to rail one seems ok no bubbles in that). Video's linked below
I installed these just fine and smeared a small amount of grease on the dry o rings to ensure no tearing and a good solid seal. 2 x hoses that have bubbles are genuine items from dealer. I am at a loss as to what is going on now and how this is happening. Any ideas would be massively appreciated!
air bubbles videos:
filter to LP pump:
LP pump to HPFP:
leak off test pic
air bubbles videos:
filter to LP pump:
leak off test pic
