280cew Auto Choke Sticking On
taylor1968
CASTLEFORD WEST YORKSHIRE
Just bought 280cew auto and the chokes sticking on.
I know very little about the engine but have been told
that the injectors are worn and it can`t be adjusted
anymore .In the worse case does anybody know where
i could get a new one or recondition the one i have.
I have been told i could change it to manual is this
correct thanks.
I need to know the car what it is WDB ?????? the next 6 numbers please
T
taylor1968
280cew auto choke sticking
Hello thanks.The first 6 no of the vin are 123053 its a 1980 2746cc
280 cew auto coupe with a automatic choke .
the trouble is when its cold it ticks over fine
then once warmed the choke stays on and won`t knock off.
a friend told me that it wont adjust anymore and the injectors
are worn if i heard right and a recondition one would be about
£380 ?what are my options and could i switch it to manual choke ?
This is a common fault or was and it is the cold start device, it happened to me when in Sweden, it was odd that the car still ran, though mine was injection.
I can only give the links to the cold start valve.
http://www.detali.ru/cat/oem_mb2.as....400&VIN=*&CT=M&cat=032&SID=07&SGR=001&SGN=01
Do bare in mind that a faulty temp sensor can cause your fault, by shorting them out would confirm if they were faulty
http://www.detali.ru/cat/oem_mb2.as....400&VIN=*&CT=M&cat=032&SID=15&SGR=001&SGN=01
popuptoaster
south Essex
were they still making carbed ones in 1980? my '75 is injection in which case they dont have a choke, most likely to be the temp sensor, check it first anyway as it'll be cheapish.
oops, must learn to read all the way down, Television got in there already. :D
