30 amp fuse keeps blowing
C220coupe420
C220 coupe 2017
Hi wondering if anybody else has had this issue but a 30 amp fuse keeps blowing which means the car wont start until you put another one in I have taken this to a mechanic and they fixed it apparently but it has happend again. Really looking for some help with this as it shouldn’t be happening on a 2017 Mercedes also worried it might go while driving on a motorway and cause an accident.
mioba
Nottingham and Köln
What components are on that circuit. Find the faulty component and replace.
Get an auto electrician if you are not sure yourself.
Srdl
Hampshire
GLC43 AMG 2018 (X253)
Welcome - or go to a proper Mercedes specialist (Independent) if there is one near you. Where are you based?
ajlsl600
france
30amp means something on starter, charging circuit. To me anyway. After check-in all abvious. Put on code reader for more specific information
Wud not reccomended replacing fuse repeatedly. It's there for reason. And 30 a is plenty
C
C220coupe420
C220 coupe 2017
Does it blow when it is raining heavily...??
It has blown before after having the car washed but then some times won’t blow at all it’s confusing it’s the fuse from the fuse box under the bonnet
mattkh
England
A160 W168 1999 1.6
Thanks.
Any chance of a photo of that area.
