Anyone assist with fixing my front seat heaters.
The dash swithches both light up, the 10 amp fues is ok and the two rear fuses appear ok but neither seat heats up. Is there a common relay for both seats which i should check and where exactly is it?
If i check voltage at the plugs under the seats which one is which and what should i get as a reading?
The other niggle is a blown lamp on left side of dash display for the dot matrix readout. Is this simply a case of dropping the trim and replacing a bulb?
Many thanks guys.
Freddy
Many thanks guys.
Freddy
