hi
my 300ce-24 engine dies if I try to accelerate rapidly from low revs , if I do it slow then its ok, similarly its ok if the revs are in the mid range when I start accelerating.In an older car with carbs the symptoms would be like those of a too weak mixture.
With the engine stopped i find there is no fuel pressure in the delivery pipes but repacement pumps have made no difference niether has new filter or the tiny filter at the supply union to the fuel ditributor .
I have also repaced the distributor cap and rotor arm , also plugs.
i am thinking of looking at the pump relay,fuel pressure regulator and rotary idle actuator but these things are so expensive for the merc
Anybody with any sugestions , advice? please
eifion
eifion
