300D brake indicator light on
Status
Not open for further replies.
M
mmahoney
Hi, this is my first post to the forum. I just bought a 1977 300D which is in amazing condition inside and out.
The only problem seems to be that the brake indicator in the dashboard is on all the time. The previous owner (who I trust) assures me that the brakes have been checked and are in good shape (they feel great), and he has even supplied me with a new master cylinder which he purchased and never installed. His mechanic advised him that everything was working correctly, and nothing needed to be replaced.
If all this is true, does anyone have any idea why the brake indicator light would be on?
Thanks!
Michael
guydewdney
Tring, Herts
www.atct.co.uk
brake wear which is somthing like ( ! ) ?
shorted wire?
fluid level sensor dead?
try disconnecting the two wires on the fluid sensor on brake reservoir, or shorting them together.
M
mmahoney
OK, thanks. Is the fluid sensor the one on top of the reservoir?
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
Could it be a faulty parking brake switch , or does this have a seperate indicator light?
Just a thought.
Regards
Mike
Mikesmerc
Co.Cork IRL
Just a thought.
Regards
Mike
thekeeper24
New York
welcome mmahoney, you are taking about the red "brake" light on the dash right? This light is for the parking brake.
In my '81 (same car'77-'81) in the past year or so the light malfunctions, come on/isn't on, but it is just an electrical problem, it appears; and i dont worry about it I have not notice any mechnical differances, just have to check to make sure i release the brake before i get going. I have had a few electrical wiring problmes thou.
i dont rememeber off hand excatly where the actual sensor is for the brake light.
there is also a brake pad wear indicator on he dash, but that is a symbol with an amber light.
good luck with your 300!
-mike
Status
