My 300E (1991) is running hot, nothing new there but after investigation the front electric auxillary fans appear not to be operating. The viscous fan passes the carrot test, but I have to say I don't recall hearing the fan noise evryone mentions.
I've done the usual, checked fuses, shorted out the temp sender with ignition on and heard the relay clicking, so presume that is ok. In the relay section of the fuse box there are another 2 fuses although I'm not sure what these are for. Only 1 fuse slot was occupied. Filling the other made no difference.
I'm starting to run out of options, I cant even find the wires for the electric fans so I could check for voltage, or hard wire them to check their operation.
My final thought is that the air con is not operative. I know it has no gas, but not sure if that is the only reason. Just wondered if the two were linked?
