Bern
- Oct 19, 2005
- Location
- Banchory Kincardineshire
- 300SE 1990 3 litre
300SE 1990. Beautiful car with 114,000 miles but has just started to run rough . I see this problem has been mentioned in the forum by other members, but I don't know where to start. Symptoms are: Difficult to start and coughs quite a bit. After 3 or 4 attempts, it will tick over at 450 -500 rpm firing on 4 or 5 cylinders. I nurse into life. It sometimes peters out at traffic lights or when I stop suddenly. Sometimes the speed suddenly picks up to 850-900 rpm and seems ok. I put it into Merc main dealer and they replaced the distributor cap and rotar arm and adjusted the mixture saying it was running rich. It now seems to be too weak. I also had a red coloured relay replaced up near the battery just in front of the screen. Prior to this the ABS light was on and I was told the faults were related. I also had a vacuum pipe replaced somewhere under the manifold. None of this fixed the problem. The car also runs on LPG and for 25,000 miles I've had no problems, but now it cuts out at low speed on gas, so I run it on petrol to be safe. I'm told there is an air valve someewhere that may be sticking and I should squirt it with WD 40. Any help appreciated
