300SE won't start!!
Tomtr250
Can anyone help me, I have an 89 300se that is used rarely, it has not run for some weeks and won't start, it has a spark and has fuel up to the fuel distributor and it will start if you pour fuel down it's throat.
Can anyone tell me where to go from here, I am fairly confident it's not getting fuel from the fuel distributor
Condensation on the rotor arm and in the dizy cap are the most common, but as it starts with fuel poured in, it could be the fuel pump relay. you could pull it out and bridge pins 7 and 8 and try the car
luders79
London
W210 estate
if your getting fuel up to the distributor then you could try cracking of each of the injector pipes to make sure its getting fuel out of the distributor! have you had the plugs out aswel if been sitting could require a bit of a clean up or replacing if its had some oil build up or are just very wet from trying to start! as television has said dizzy cap and rotor are most common! have you got a strong enough spark?
roofless
w124 e220 estate
if you turn the ignition on & listen for the fuel pump running for a few secs to prime the system if not try the relay ...as per television
T
Tomtr250
Hi Thanks for the info, the car is sparking and I can hear the fuel pump running, fuel is being delivered to the fuel distributor but when I crack open the pies on top there is nothing, is it stuck? how does it work?, do I need to throw it away??
thanks for the help so far
Disconnect the fuel pipe return from the pressure regulator,use something to catch the fuel. bye pass the fuel pump relay by joining pins 7 & 8 to check that fuel is coming out
T
Tomtr250
Hi television, can you point me in the direction of the relay please
Tom
teddycatkin
cheshire cheese country
Hi Tom -not sure where you are up to now but its sounding very much like the relay-before you pull it all apart just connect 7-8 pins together as ipreviously instructed -with a few stands of copper electrical wire twisted together --push relay back in and try it ??
roofless
w124 e220 estate
if you can hear the pump run & it has fuel at the metering head why bridg the relay
The pump running at start up is no indication the that the fuel pump relay is working, it will run when you turn the key and then stop until it gets a pulse from the CPS.
With 7 and 8 bridged you do not put the relay back.
A wire with 2 4mm banana plugs is perfect
