300sel using too much gas
Y
youngil006
I have a 1988 300 sel mercedes benz, and it uses way too much fuel. It used to get 400 or so miles to the tank...now it goes about half or less. These are the symptoms:
1-start to engine with no need to push down the gas pedel
2-put in drive, push down gas pedel no respose until i push it down all the way to the floor... car hesitates, then engine revs hi then i get pushed back into my seat, the the car takes off like a bat out of hell, black smoke leaves the pipes. when on high way car runs ok, but has very strong gas smell.
3-when in idel car economy meter stays in the middle, never gets lower until i put it in park.
is there anyone out there with some mercedes knowldege?? my wallet is getting lighter every day paying for gas.
thanks
*young006
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
Could the cold start injector be at fault, in other words staying permently on making for rich running. You could try disconnecting the plug from the top of the injector and see if there is an improvement. It should only activate on cold starts.
Mike
sooper coop
Weybridge
I have treated my 300 to its second bottle of Injector Cleaner and there is a very noticeable improvement in mpg.
your injectors are definitely fouled up whatever. its a cheap way to start the diagnosis
MondeoMan
2 inches from your rear bumper
The symptoms suggest it's running very rich all the time (which would probably rule out a problem with the cold start). I suppose you've checked the condition of the air filter? Air flow meter problem?
mlc
South Manchester
2001 S320, 2003 SLK230, 1972 350SL
this is strange - i thought I posted on this before work today !
you are describing a blocked air filter (just as my learned friend MondeoMan says). Either the filter is blocked or you have picked something up in the intake piping.
But what do I know, I only drive a Mondeo :)
Mark.
