Unsound Methods
- Dec 20, 2013
- Location
- Kent
- Mercedes 300SL-24 1991
evenin'. Hope everyone is surviving the clement weather....
I'm assuming i have an electrickery issue so assuming i'm posting the right section... On turning the key in the ignition the dash lights all come on as usual, the fan and stereo all work fine but the car doesnt even turn over. This happens when the car is both hot or cold. It doesnt happen all the time, but when it does, if i keep trying it eventually turns over and fires up.
As I type i wonder if the starter motor is on the way out but the research i've done so far is suggesting a fuel relay issue in the MAS control unit. Does anyone have any other suggestions as to what might be stopping the car turning over?
Not sure if these 2 issues are related to the above but ....:
• my full beams have stopped working (no blue light on the dash also)
• on starting from cold and setting off the car will stall as i slow down - usually at the first junction i stop at, as the revs drop - but it starts up straight away on turning the key. It doesnt stall after a few more minutes driving.
cheers, Dani
cheers, Dani
