I have a 1998 300TD which i previously posted had a rattle which i put down to engine mounts as they are a weak spot. I had the mounts changed and also the worn linkage arm bushes.
The new exhaust was replaced under warranty and it still has a noisy rattle which sounds as though there is a hole through the firewall as it is coming into the cabin.
Outside it sounds a bit trucklike!
I would say there is part of the drivetrain knocking on the body but my mechanic has had it on the lift and cant find this problem.
When in gear (auto) it rattles but stops momentarily if you move into neutral.
Any ideas please??
#Thanks
Freddy
Any ideas please??
#Thanks
Freddy
