300te cruise control
smithie
landsend cornwall
hi guys
well my 230te cut out problems that i mentioned on another post seems to have been cure(touch wood) so thanks to all of you for your help in that matter!
over the weekend i got a 300te estate,at present ive only found two things wrong with it (its early days yet) and they are...cruise control does not work,checked fuses,all ok,does anyone have any ideas on where to begin to track down the problem? i havent got a clue what makes up the cruise control so dont know what to look,or where to look for the parts,culprit!
the other problem is the oil pressure gauge,when you switch the ignition on the needle goes straight to the top( ie 3) do you reckon it could be a faulty oil pressure switch? if so any ideas how much and where abouts it is on the single cam 300te engine?
any help with these points would of great help!
many thanks
smithie
