380sl 1982 fuel pump relay ???????
mercurytel
Help can anyone tell me where the fuel pump relay is on my 380sl 1982.
i have looked behind the battery and glove box but it is not there. i need to find it as my fuel pump packed up, i replaced with a new one but am now
not getting any electric to the pump. i have been told it is the relay ?
but where is it can anyone help please:confused:
M
mercurytel
Thanks Malcolm would i be correct in that this relay is located in the fuse
box in foot well drivers side
Thegemmesabogie
Blackburn
W124 320TE
You would be correct in that. Go get yourself a double-jointed spine to get at it though. It's waaaayyy up there tangled up with all the wiring harness.:-x
No, its easier to lay on the roof with some one holding your feet:rolleyes:
If you can open it up they normally just have a blown track on the PCB if there is one.
Malcolm
Thegemmesabogie
Blackburn
W124 320TE
No, its easier to lay on the roof with some one holding your feet:rolleyes: Malcolm
Malc. As you well know that only works with the optional OEM anti-gravity suit. Part No W107As 1F 36 22 36...or for left handed folk 36 22 35. Not all SLs came with it.
Your right,I forgot that,but I dont think it works for the soft top. My memory is not as good as it was when I lived just north of Watford. :D
malcolm
M
mercurytel
Thanks for info i have found it part number 001 545 34 05 black box with kickdown written on it i just hope this is the thing that is causing the problem
as i understand they are very expensive thanks again
Myros
R107, S211, R170, C219
try Mercman and Dronsfields and other MB breakers
the Kickdown/fuel pump relay is pretty common across the same sized engine models of Mercs from similar years. That broadens the field of search a bit. Check the part number of the russian site from 380 SEs, 380 S, and see if they are compatible.
Try this site to see if you can cross-source your relay.
http://www.programainc.com/doc/M-Benz.html
M
mercurytel
380 sl 1982 help i am still having problems after fitting a new fuel pump and relay no power is getting to the pump therefore no petrol getting to engine
what else could this be
With a volt meter you need to check that you have 12volts on the plus lead but also very important,the other lead must go to ground (chassis) the fault could be on the minus ground lead.
The other way to check is to take a single cable from +12volt and join up to the + on the pump,but take the wire off the pump first. if that does not work, then try grounding the other - terminal
Malcolm
M
mercurytel
Hi Malcolm i tried a wire from my battery directly to the fuel pump and the pump works ok. car still did not start is this because of the fuse pump relay ?
Your next move is to check that you have 12v going to pin 30 of the relay, you can do this with the relay removed for easy access. key2
the car will not run without the relay as it is also the engine speed limiter.
Malcolm
