I have a c180 2004 (possibly w203?)
I changed the battery at Christmas because it went dead in cold weather and had trouble getting it back up.
Since then it has been harder to keep the new battery charged. There seems to be plenty of voltage when driving and it seems to finish a journey with more charge but then drifts down. Then last week, parked in hot sun, it decided it was unhappy and went into "alternator error go to workshop" and limp mode at 30mph with all electrics disabled. It then put out 17v on the way home, which probably didn't do the battery any good. On getting home it would still start but by the next morning the battery was dead. I jumped it and once jumped it was perfectly happy which suggests it was just the battery being a bit low that bothered it not the actual alternator? I had to disconnect the battery to get it to trickle charge.
I put a multimeter on it today between the negative and the battery terminal and it read between 3.2a and 4.2a which is presumably about 40w. I pulled virtually every fuse out in the engine bay, the passenger side and the boot. None of them seemed to help. I did not remove all the square cube block things plugged into the fuse panels. This presumably means it is drawing 40w which seems alot. Where is it going? I left it for half an hour on the multimeter in case something would go to sleep but it stayed at around 4a. Which explains why I struggled to charge the battery.
Any ideas? Taking it to the garage is the obvious but it would be nice to have an idea of what is wrong first. What can draw 4a without an obvious fuse?
I don't really know what I am doing so easy answers if possible please... Starting to wonder if its time to scrap it. Still drives very nice but...
