51 Plate s500L Problems
Hi there , Iv bought a lovely s500L 2001 .
Its great but just got 2 little issues:
1) The AC OFF light wont Turn OFF
2) The command system says TEL ERROR - NO PHONE CONNECTED
but I have phone in arm rest and it works on its own but DOES NOT work with the command system...
Any ideas where it plugs in or what I can check...
Matt
Cole@MBS
www.mbssouthampton.co.uk
The aircon sounds like it has a stored fault, needs clearing with star, the phone fault is Malcs department!!
Matt
The air con could be off as it is low on gas, maybe a sensor, but check the gas first.
You car will be made for a nokia 6210 or 6310i the coding version of the phone must be 5.5 or higher
barry jones
Warrington
2016, LWB W222 AMG Line S-Class S350d - W415 Citan Van too :)
I had that problem when I fitted the phone system into my car Matt. Tell Error was showing on my display because I was using a 6310 phone in the cradle and the phone module was a 6210 one. I bought a 6210 of fleabay and it worked....then I bought the Visseo unit so my Iphone works now!
Still got the 6210 if you want to try it out
Baz
M
Phone problem
Hi Guys
the Phones in the front and back of the car are both Mercedes branded nokia hardwired phones (Not the cradles as found on some other cars)
I have tried the sim card in the phone and it allows me to make calls using the handset receiver But It does NOT work with the command system..
The command unit just displays "TEL ERROR" "PHONE NOT CONNECTED"
when i press the TEL button on the command unit..
Any ideas what could be wrong ??
Thank you all for your advice and help given previously :)
M
Service Menu
Hi .
How do i access the service menu ???
THANKS
I will take a look later in the day
