55 plate e320 cdi radio replacement
Ad777
1999 C250 TD estate W202 engine
Hi all, was wondering if anyone has replaced the stock radio with a single din head unit? I have done it a few times with other cars, buying a single din cage and fitting was always quite straight forward with the plugs on the back being interchangeable. Be good to know if I need anything extra, harness etc before I start! Help and advice appreciated as always.
A
Ad777
  • #2
Thanks for moving, sorry in wrong one.
mattkh
England
A160 W168 1999 1.6
Please put up a picture of the rear of the radio you want to fit PLUS the connector ends of all the cables hanging from the radio making sure the colours of the wires are clear. Thanks.
A
Ad777
I will do it in the morning, thank you!
A
Ad777
A
Ad777
Hi there, heres a few, if you need any more please just let me know! Help appreciated.
Looks like standard iso fittings so replacement should be fairly straightforward and mostly plug and play.
You might need an adapter to power the antenna amp via the co-ax (I can’t remember if Mercedes use the antenna lead to power the amp or not (a lot do))
A
Ad777
Grand! Thank you. Waiting for the cage to arrive then will take out and investigate. Don't have the original radio code, so don't want to disconnect before I am sure it will work! Appreciated.
A
Ad777
Any info where I can find such an adaptor if need be, please?! Thanks
A
Ad777
Ok thanks, I will investigate further. Cheers.
