Steve Jowett
- Dec 7, 2019
- Vito 111cdi 2004
Hi all, Hoping someone can shed some light on a problem. The heater fan suddenly stopped working in my 2004 Vito (no A/C). Thought it was the usual so bought a new resistor pack. Still nothing. Changed the heater controls for a supposedly known good pack. Still nowt.
Put old resistor pack back in. In fact tried all combinations. Got the multimeter on the connectors. 12v to the switch, nothing out on any speeds. Bridge the contacts on the connector and get all 5 speeds!
Took the switch pack apart and there's a tiny 'fuse' strip on the fan switch connections which had melted on both switch packs. Can only assume it's a fail-safe in addition to the actual 40A fuse. Worked out it is a 30A maximum draw on the blower motor so soldered a 30A fuse wire to bridge it. Re-assembled and it all works!
Only trouble is, it is now permanently live, i.e. the fan works even with the ignition off, the key out and the van locked. So I have to remember to switch the fan off to '0' before I leave the van.
It's driving me mad! The Merc wiring diagram doesn't make sense to me either.
Does anyone have an idea? Please. Or I may take my Kango to it!
TIA
TIA
