651 Engine Bolt Torques
M80
Derbyshire
I've failed in trying to access manuals, and online info contradicts each other often.
So help appreciated on the torques and torqueing patterns of
Head bolts,
camshaft hold down bearings,
injector clamping,
inlet manifold.
New injector hold down bolts and copper washers - tick.
Head bolts reusable ?
Any other heads up warnings appreciated.
mioba
Nottingham and Köln
I would be inclined to use new head bolts.
Have you a friendly indy / dealer who can give the torque settings from WIS.
M80
M80
Derbyshire
No unfortunately, I was hoping I might find one here.
mioba
Nottingham and Köln
I am sure someone will pop on soon with the info you need. There are a few indies who frequent the site.
  • Like
Reactions: M80
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
Head bolts,
injector clamping,
inlet manifold.
I have the Haynes Manual settings but I suspect they are part of the conflict you refer to? Herewith is a photo of the relevant section anyway FYIP
ETA The (See Text) reference is a statement of 'Do Not Reuse'
  • Like
Reactions: M80
M80
M80
Derbyshire
Tony Dyson
God's Country
but since this supplier has questionable feedback I'm reckoning to use this
but any comments welcome.
Don't you mean Positive?
I don't see a big difference in the torque settings either, there's 0.5 lb/ft more in the 1st two stages in the online guides with only two further 90° turns whereas the Haynes Manual indicates 0.5 lb/ft less in the 1st two stages and 4 further 90° turns? Go for it! :)
M80
M80
Derbyshire
Maybe I didn't write it clearly,
1st link is questionable, 2nd link has good feedback.
What I'm seeing is 1st pass 10N/m, 2nd pass 50N/m +90, +90, +90, +90.
Rotational pattern from the centre.
20N/m for the 3 M8 bolts
It's no wonder the bolts took some undoing.
