Cannabat
- Feb 13, 2021
- Jeep GC 2006 (OM642 / 722.6)
I have a Jeep grand cherokee 2006 with OM642 engine and 722.6 transmission. Purchased a couple months ago. 270,000km on the odometer (100,000 on the engine).
It runs great except for some intermittent issues with shifting. When first starting up the car, all shifts are perfect and smooth.
After a few minutes driving, particularly when braking firmly, there may be a harsh shift around 40km/hr and again around 25km/hr. The 25km/hr shift is worse. It feels like getting lightly rear-ended, or hitting a small pothole. Doesn’t throw me out of my seat or anything, and if I’m driving on a lumpy road it’s hard to notice.
It doesn’t happen all the time. When coasting to a stop it probably won’t happen or will be very subtle. When braking hard it will definitely happen.
I’ve had the trans fluid fully flushed and filter replaced, and the transmission learned adaptives reset. Done at an automatic transmission specialist.
I inspected the two TCM connections (at the TCM) and there is no oil at all there.
I’ll be contacting the trans specialist again this week but am hoping to get some other opinions here, where there seem to be a number of very knowledgeable folks.
I’m wondering if replacing the conductor plate and that cylindrical connector in that area - and perhaps install the sonnax master overlap kit and pressure spring while the valve body is off - would be reasonable next steps. Or could this be related to torque converter lock up?
Sometimes the up shifts from 2-3 and 3-4 felt late but the tcm reset fixed that while it didn’t affect the downshifts.
Thanks for your time and any advice.
