Hi Guys. How far do you need to "push in" the dipstick..? Until it stops ? Then the dipstick is more or less in a horizontal position ? ThxGet a transmission dipstick and stop guessing.
Thanks ! I have a problem with my Slk 200 R170. All of a sudden all gears gone. Replaced the ATF and filter. Gearbox and shifting fine...After driving for 2 days...same problem..heard a funny noise..whining noise...2nd time...gears gone again. After an hour..limited gear shifting.. What I observed..."new" ATF looks dirty...not clear red colour.. ? Please advice..should I flush and replace the filter ..again ?722.6 auto box according to VIN numberYou push it in until you can feel the tip hit the bottom of the sump.
You can buy a new cap for a couple of quid on the bay. I bought 2 as I also like to drop things into the engine bay, but mine always vanish. I think there is a black hole down there.Update,it drives very well,shifting is definitely better and smoother, occasionall hesitancy to shift is gone, loss of drive did not happen in 120 miles yet,although it did not happen frequently before.It might be just my imagination,but maybe the revs are little bit higher at constant 40 mph,but no more then 50 odd revs.Also managed to drop gearbox oil dipstick cap into the engine bay,hope it is still there...Now my engine oil dipstick is missing the handle on top that shredded serpentine belt broke,and sticky tape on the gearbox oil dipstick is a testament to my clumsiness...Added a bit more gearbox oil, now it is 4 liters in total,only measured at cold level so far,it seems to be ok,will check again after longer drive how it seems at hot temperatures.
Thx for the advice. Apparently you cannot drain the T converter on this model..Slk 200 (2002) model ? Cant see a drain plugI'd be inclined to do the cooler return flush a couple of times until the fluid gets cleaner. I wouldn't change the filter again. That's just my view, though.
