722.6 only has first and reverse
5pares
Suffolk
E320cdi
As above?Ive been offered an 210 e220 cdi with a box problem,anyone know what the problem is?electroplate?
Yes it will be the plate £135 plus fitting and easy to fit, and do the filter and fluid at the same time
5pares
Suffolk
E320cdi
Thanks,is it a speed signal problem then?
You could get the codes read out
002 to 007 stored is the ECU
012,013,108,109 is loose connector on ECU
If the car had lost the speed signal then other things would show up, so the fault should be within the box, a read out will tell you
