AdamG
- May 24, 2009
- Location
- Bromley, Kent
- S320CDI (2003)
Sorry I should say I've had the spring kit fitted by the professionals
I do get TC drag when cold but none of the other symptoms.
One of the reasons I went that route was a post I read about Sprinters vibrating on gearchange where the only solution was the lockup clutch plate spring kit. Also I think the later 7G plus boxes' lockup clutches are mechanically spaced i.e. do not rely on fluid pressure to release. To be honest I'm trying everything now
I've had my gearbox in pieces and it all looks in very good condition. The only possible issue is a little wear on the pump bushing. I recon that was where the gold speckles came from in the pan.
I've attached a photo of me changing the rear stator bearing.
