davetapsom
- Feb 3, 2019
- C180 Sport Coupe 2003
Hi All
My first post...
I have a 2003 C180 Sport Coupe. It has started cycling malfunction messages: ESP then Coolant then Display Malfunction. Sometimes it goes into limp mode for a while then jumps out after 30 secs or so. Occasionally will not start - turn key, nothing happens.
Hoping against hope, I replaced the 13 pin transmission socket but am still getting the codes. The car does seem not to be going into limp mode. I did disconnect the battery but I have not yet had the error codes cleared.
Dunno if anyone has anything to suggest?
But another question: all the forums say 'change the connector because oil gets in'. If you look at the socket, there are the 13 pin holes plus locating slots. Are those not going to allow the oil to get in? Unless on the locating plate/slots there are a bunch of rubber seals, it seems to me that oil will get in anyway?
Regards
Dave
My first post...
Regards
Dave
