yinujim
- Dec 21, 2015
- Location
- Essex
- 92' 500SL, 04' E500 Estate
Hi guys my E500 is on axle stands at the moment. After a day I noticed the whole pan was wet. I did replace the gearbox oil and filter and fitted new bolts torqued 4nm then 180 degrees. I nipped the bolts again and the leak has appeared again. Because it looks like I have to drain the oil and drop the pain again I would have to order new bolts again because they are alloy stretch bolts. Is there a replacement stainless steel option instead of using the original torque to yield bolts which love snapping?
