WonkyWombat
- Jan 12, 2022
- W204 C250 SPORT CDI 2011
Hey all - I have an issue with my car and looking for some advice.
W204 2011 SPORT C250 CDI (Facelift model) 7g - 108k miles
Gearbox has been serviced every 30k - It's been about 30k since the last time so it is due.
P1843 Torque converter lockup clutch (KUeB) Y3/7y4
There may have been another error but I can't remember I'm afraid.
The issue:
Sunday:
On sunday, went for a drive, was cold. It felt as if gears were "snatching" and "holding" revs whilst driving, it wouldn't change when needed - thought this may have been DPF due to it being cold.
However, the biggest issue came when i went from 2nd > 1st coming to stop, the car snatched gear 1, and felt an abrupt gear change.
Fast forward 1 day (Monday)
Book the car in the garage (merc specalist) they banged it on STAR and it came back with the error:
They mentioned STAR tells them to rip out the torque converter, and change it. However, driving there, it felt fine. Literally no issue at all. The gears changed when needed at slow speeds + faster speeds, and you wouldn't have known there was a problem.
Then in the evening, I needed to pop out, and my car felt quite normal, maybe a bit sluggish which I put down to the cold, I drove about 4 miles, and the car went into limp mode. No EML, warning lights etc.
Pulled over, turned car off, turned it back on and went back to normal without limp mode I then nursed the car slowly home, pulled up, and have left it.
My options are:
New torque converter = £1800-£2300 (ish)
Refurb my old one at a local auto specialist (£850)
Get ATF fluid change (£240) and hope this fixes it.
Has anyone came across any similar issues, and any advice as to if you think it is the torque converter, or maybe lack of oil/bad oil? Or any other advice?
Is it possible to replace just the torque converter, or is it advised to replace gearbox too?
The issue:
Sunday:
My options are:
