Dav1992
- May 17, 2022
- Mercedes E class, 2011, 250
Hi all,
I had this issue for a while now with the E class coupe 250 11 plate. I am very unlucky with the car as it had a lot of work done and I'm still in the same place, sadly.. basically I feel as if it struggle especially from 1st gear to 2nd and 2nd to 3rd when it's in ECO mode, that's when I put the foot down. It doesn't change the gears as smooth as it should. 4th 5th 6th all the way to 7th is fine. Any idea what could it be? I had engine mounts as well as the gear box replaced not long ago and the car felt so quiet and it seemed like it sorted the gearbox issue only for few weeks and it's back to normal now. I also had gearbox service done a year ago and had torque converter replaced as the indy said it would sort it, but no luck. Anyone had the same issue?
Sorry for the long paragraph, but hopefully someone else had the same issue in the past.
I have attached pictures with codes for the reference.
