Hi; I spent some more time underneath the Car this afternoon; I see the support bracket on each side: cast aluminum, two large bushing isolators between it and the chassis, and it matches the part ilustration I found. It seems to possibly be repairable or rebuildable: there is a square plate about 8cm x 8cm, with four Allen-head bolts holding it, on the rear side. Since my brackets seem structurally sound, can they be rebuilt, with a new "ball" (seems to fasten to the rearmost end of the "support" or "trailing" arm and "socket" (behind the square plate held by the four Allen-head bolts)? :?:
The parts illustrations I found on-line also list a "guide rod", and a couple of different repair kits for this same "guide rod"; is this a repair kit for the same parts? :?:
Regards and Thanks
Regards and Thanks
