Hello; I need advice on connecting the original radio to the harness: which male spade terminal does the harness wire with the rubber-covered end go on (there are two choices; all other wire connections are obvious)? My radio blows the chassis (mounted on the back of the radio) fuse when turned on; Becker says there is nothing wrong with the radio. Can a failed power antenna cause this? :?:
My sunroof motor runs, but the roof does nothing; I can hear the drive cable moving in the roof rail. How can I get the roof partially open to get it apart? :?:
