HI,
I am new and i from Singapore,
my car has the following problems and seek for help..
As i pull into gear D, the idle drops a lot (300rpm) but then comes right back up to 750rpm within 2 sec...when i pull back into N, it shoot up to 1200rpm then comes right back again..
If i full turn the steering during gear D PULLING, the engine will stall.
my indy mech said i got a worn engine.
things tried: coil, plug, wire, fuel pump, fuel filter, fuel distributor, fuel accumulator..
when cold start: the rpm will remain at 750, same as hot...
ANY IDEA PLS AS I WANT TO KEEP THE CAR.
ian jak
ian jak
