88 230E ABS Light on
Status
Not open for further replies.
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
Hi all
some time ago I got the front shock replaced and ever since then the ABS light has been coming on and off but now is staying on. I suspect its a faulty sensor on this wheel but is there any way of checking which sensor is faulty. I traced the wire up into the inner wing but am not sure where it connects to. There seems to be connections on both sides of the firewall just in front of the damper top nut, are these the sensor connections(looks like an arial connection)?
Mike
kiwi_bloke
New Zealand
multi meter
i did this a while ago. I know you need a test meter to test voltage coming from the senser while you are spinning the wheel. Any one got the values?
Status
