D
davekmoore
The main handbook tells me to use 95 and the supplement says 91.
Which is correct?
Which is correct?
Can you still get 91 octane petrol?
These cars will run on 91 but 95 is better, just avoid too much hard acceleration when using 91
Use 95. I think you will find your fuel economy will drop a fair bit if you use 91. Measure it and see........
That is all you can get in some countries
He's right.... My W124 says to use 95 octane, but I'm in the habit of putting in 98.
I now average 70km more per tank of fuel, and the performance is so much smoother.
Which is correct?
Use 95 Octane as that's what the car's ignition advance curve and compression ratio is designed for. The engine ECU will alter the ignition timing to allow the car to run on 91 octane but as has been said power and economy will suffer -possibly to the extent that any money saved on fuel will be negligible. It may also run hotter. With 4 cylinder engine hauling a W124 estate you want all the power/torque you can get!
