93 190E 2.3 Check Engine Light on - No diag info
Ms69Mach1cj
New Registration
I have a 93 190e 2.3 that has the engine light on. The car was running fine. I had driven the car that morning, and about 2 hours later I went out and when I started the car the Check Engine light came on and wouldn't go off.
I replaced the battery about 4 months prior to that. I also replaced the alternantor about 2 months prior to that.
When I took it to my mechanic he could not get a reading from the diag unit.
I called Mercedes to see what they would charge me to put it on their diag machine, but the cost was $300 for 2 hour minimum. They also said they felt that the Engine controll unit may be going out which may be causing no read out from the diag unit.
My dad and I have attempted to check the diag unit our selves. There is no reading. We've checked the voltage, etc.
Anyone ideas or suggestions is apperciated.
Thanks!
BlackC55
South coast
C43
Get the engine control unit re-furbed. It won't be that expensive to have done. A google search will find you a repairer.
www.ckinsurance.co.uk
