94 W124 E300D Replacing Glowplugs
Well, I said I would report back on this job which I carried out on Saturday, so here goes:
It's not particularly difficult but it is a bit fiddly and it had me questioning the sanity and parentage of the person who designed the positioning of the fuel pipes and oil filter housing. The whole job took me 4 hours.
I bought a long (12mm) socket to fit the glowplugs. Two of the glowplugs are obstructed by fuel pipes and no. 6 glowplug is behind the oil filter housing so it's not possible to get a ratchet onto the socket on these three glowplugs. Fortunately my socket has a hole in the end so that a small screwdriver can be used as a tommy bar. All six glowplugs came undone very easily (luckily!).
I managed to salvage and reuse the original inlet manifold gasket but it would have been better to fit a new one.
This is how I did it (with reference to the drawing that someone kindly posted on the original thread):
1. Remove the rubber hose from the air filter housing to the EGR valve housing (part 77).
2. Disconnect the linkage from the throttle to the EGR valve by prising off the ball joint with a screwdriver.
3. Remove the clamp that secures the pipe from the EGR valve to the exhaust manifold
4. Undo four bolts and remove the EGR valve (part 77). This is sealed to the intake pipe by a rubber seal and required a bit of heaving to pull it off.
4. Undo two bolts underneath the intake pipe (part 29) on the right hand side and one allen bolt on the other side and pull it off the manilfold.
5. Undo the allen bolts securing the plastic cover on top of the engine and remove it. This will reveal the crankcase breather hoses which are plastic tubes joined together with rubber connectors. There are 8 rubber pipe connectors which are a push fit into holes in the top of the inlet manifold.
6. Prise off the throttle linkage to the injection pump from it's top connection.
7. Undo two bolts securing the throttle linkage assembly and remove it. To remove one of these bolts I first had to remove the middle section of the crankcase breather pipes and when I pulled the two rubber connectors from the inlet manifold they both snapped off in the manifold because the rubber had hardened. At this point I decided not to remove any more of them.
8. Undo all the star drive bolts securing the inlet manifold to the cylinder head and lift the manifold enough to allow access underneath. Then pull off two rubber tubes and two electrical connections from the valve on the underside.
5. Remove all the glowplugs and fit new. This tested my perserverance somewhat. Two of them had to be unscrewed one flat at a time removing and repositioning the socket each time. I'm sure there must be a better tool for this job but if there is I haven't got one!
The inlet manifold and inlet ports in the cylinder head were considerably bunged up with black oily gunge which I spent about half an hour cleaning out.
Reassembly was straightforward except for refitting the two rubber plugs which had sheared off. I suppose I should really have waited until Monday and bought some new ones, but I needed to use the car so I wedged a piece of rubber underneath the plastic cover to keep them pressed in position.
I think that's everything. The engine now starts as it should and also seems to run more smoothly.
Hibbo
East Scotchland
Thanks very much for that, I'm reassured that they came out easily.
I think I'll splash out on a 12mm ratring spanner as access is so tight.
What glowplugs did you fit and how much/where from?
Hi Hibbo,
They were Beru glowplugs from GSF Car Parts and they cost about 7 quid each.
Cheers.
Flying Scot
MOZZERWELL North Lanarkshire
SL 500 R129 1995
Hi Hibbo,
Cheers.
he he SEVEN POUNDS - TOOOOOOOOOOOOOOOO expensive for Hibbo
However did you clean out the holes where the glow plugs sit i am told this is 'essential' if you dont want stuck/seized glow plugs in the future i am told there is a special tool 'a reamer' to do this - ooops sorry to rain on your parade :rolleyes:
Hibbo
East Scotchland
Damn right, I'm not ****** made of money you know!:eek:
Does anyone know if there's a Merc tool for doing this? (part no anyone?)
Or can anyone tell me what size thread they have and I'll buy tap or reamer of that size.
Didn't need to clean the holes they were perfectly clean.
The new glowplugs screwed in easily by hand. All I did was smear the threads with some high temperature paste that a mate recommended. Can't remember what it was called but it came in a tube (cost six quid!) and looked just like ordinary copperslip but it can withstand up to 1100C.
amt29
Bristol, UK
2003 W211 E320 Estate
E300D glowplug replacement
I have just replaced the glowplugs on my 96 W124 E300D (OM606).
Thanks to SlowlyButSurely for his excellent help listed on this forum.
The symptoms were lots of smoke from the exhaust and the engine 'chugging' when starting from cold, runs fine as it warms up. The glowplug warning light seemed to be working normally, coming on for a few seconds and then staying off when the car is moving.
Searching various forums made me suspect either air in fuel filter or a glowplug problem. Service History showed the O-rings around the fuel filter had been changed fairly recently, so decided to check the glowplugs. I used a current clamp meter to check the current being drawn through each glowplug feed wire. You can pull back the conduit near the glowplug relay and there are six differently coloured wires running to the six plugs. 17Amps flowing through five of them, only 0.5Amps through one. Definately a faulty glowplug! (You can also check the resistance of the plugs to chassis - should be less than half an ohm - and you could probably do this inside the relay box)
The main problem I had was getting the glowplug nearest the bulkhead (plug G6) out. It took about 3 hours using a ring spanner to unscrew and then a combination of lubricant, screwdriver and spanner to lever it out. Its so close to the oil filter housing I couldn't get a socket spanner in there. All the other plugs were much more accessible, but all were very stiff when pulling out.
I wish I had had some sort of reemer (can you get a specific one for this job?) to clean out the glowplug sockets as the new plugs were also very tight to get back in. I guess there is lots of carbon build up that compresses down as you screw the plug back in, causing a very tight fit.
Once all were done, fitted a new intake manifiold gasket, tried to remember where everything went and it now starts great!
