immobilized
- Jul 8, 2006
Hi there i'm new here. I fitted an alarm into a 97 C280 today and started it numorious times while fitting. After finishing the alarm and putting the car back together i did my final check of the car and it wouldn't start. Now i checked all my wiring and even removed the immobilisers and had the car rewired back to it's factory state and it still won't start. There is a 12volt feed from the ignition down the starter wire when turning the key. I checked the fuses i could find in case there was a blown fuse but everything seems ok. Does anyone here know of the location of all the fuse boxes in this model or know what is causing this problem as it has me stumped.
Cheers
Cheers
