97. E-300. Td. 7 seat. Est. Rear suspen. Bumpy ?
HERBIEMERCMAN
PRESTON, LANCS.
97. E300.TD. 7 SEAT.ELEGANCE. EST.TOYOTA SUPRA MK4. RS. VAUX. CORSA.GLS AUTO. SPORT.
hi everyone, my vehicle has a hydraulic self leveling suspension system with oil resavoir and a belt driven pump. recently the oil level in the oil supply resavoir has risen 2cm.above the max mark, the rear suspension seems to have lost it's cushion effect, it's bumpy. history,some months ago prior to me having any problems my local garage changed all the hydraulic pipes as one of their mechanics mistook them for brake pipes and destroyed them. he also sent a veh. out without gearbox oil and was dismissed. the cost of new pipes and fluid cost me £150. and some messing about, merc. won't supply the pipes, and we tried copper pipe, which leaks due to diff. expansion. as the pipes get hot, had to order 6mm bundy and make a flaring tool. as far as i know my garage, who are very good, bled the system at the valve just above the rear axle. does anyone know what could have gone wrong shortly after the work was done ? herbiemercman.
I will have a look to see if there is any special way to fill it
As the rear sink,then it will push the fluid back to the filler tank, so the pump is not pumping.
Are the pipes all good at this point in time
HERBIEMERCMAN
HERBIEMERCMAN
PRESTON, LANCS.
hi malcolm, all pipes are good with the majority replaced last year. could the system just need bleeding? presumably this would have to be done with the engine running. when the system was working prior to the pipes being changed they used to get quite hot, so i suppose i could check if the pump is working by feeling at the pipes.herbiemercman.
I have a bit of info on this and later in the day I will see what I have on this, anything worthwhile I will print off and send to you
HERBIEMERCMAN
HERBIEMERCMAN
PRESTON, LANCS.
hi malcolm, my local garage friend tells me the spheres are gone, i contacted my friend at dronsfields and he said for the cost differece he would fit new ones, it is also not possible to test secondhand sheres other than driving the car. i have ordered them from mb main dealer. £110. inc. vat. each. ian. herbiemercman.
Hi Ian,,If you need anything or guide just ask
tjamesbo
Sutton Coldfield, West Midlands
1999 CLK430, 2007 VITO 3.0V6 , W124's (1994 320TE , 1993 220TE ) , 07 2.5 X-Type
Changing My rear spheres as well
My 93 220TE is getting its spheres replaced this weekend ( if weather is dry ) by myself, following the procedure posted by Andy _k I've ordered the spheres, 2 new pipes ( the ones from the sphere to the levelling unit ) ie not the expensive ones. and some seals. got a shopping list for nuts spanners etc
So would be interested to hear any additional feedback from anyone who has done this job.
The Crooner
Woodhall Spa Lincolnshire
2006 R320 cdi
Can you take some photographs and post up a howto?
Tony
