HERBIEMERCMAN
- Dec 15, 2008
- Location
- PRESTON, LANCS.
- 97. E300.TD. 7 SEAT.ELEGANCE. EST.TOYOTA SUPRA MK4. RS. VAUX. CORSA.GLS AUTO. SPORT.
hi everyone, as i am waiting for my maf cure i thought i would tell you about the excessive corrosion you can get on the engine lower support cross member. this can happen on any of this model after 3 years, forgive me if this situation is allready known about. what causes the problem is the plastic cover which runs under the engine fills with water from the aircon and also rain water, about 2 cm deep, this submerges the base section of the lower engine support cross member which is mild steel and not designed for continuous submersion in water. the complete base of my support was 80% corroded away with everything else in the area including all the upper parts of the crossmember as new, this happened at the 5yr old mark on my vehicle, it was obviously ignored by the service people at HL GORNER merc main dealer of warrington,who supplied the car, you could not miss it when you were changing the oil. hope no one is suprised at their attitude! the base of the crossmember was cut off and a new piece of 8's gauge steel plate welded in place, then painted and waxoiled. the plastic lower engine cover had several 8mm holes drilled in it to avoid any further water pooling. herbiemercman.
