HERBIEMERCMAN
- Dec 15, 2008
- Location
- PRESTON, LANCS.
- 97. E300.TD. 7 SEAT.ELEGANCE. EST.TOYOTA SUPRA MK4. RS. VAUX. CORSA.GLS AUTO. SPORT.
hi everyone, i traced a high frequency rattle to the top fixing boss on the front of engine damper, i removed the top 8 mm set screw and found play in the retaining bush. the problem i encountered was trying to remove the lower 6mm retaining set screw, as some of you will know, it fouls the featherin fan drive pulley. the question i have is do you need to remove the featherin impellor and then the pulley ? and how do you remove the plastic fan blades from the steel pulley? surely the radiator does not need removing, i say this as the gap is only 2 inches from the fan blades to the radiator fins. many thanks. herbiemercman.
