Was the battery flat and if so how long did you take to replace it. As per another thread you generally have around 2 mins to replace a battery otherwise it needs re-syncronising to the car.
Do you have the other key and does that work?
No I only have 1 key ...Battery wasn't disconnected. Can re synch be done by someone coming out to the car or do you have to get it to a dealer..nearest one is 70 miles!!!
There should be a procedure in the manual for re-sync. However if you cannot get it to turn in the ignition then that won't work. Are you sure that the batteries in the key are good?
How long were the batteries out of the key before you replaced them?
If you could find the other key that would be a benefit
MB service will come out to you it may be worth giving them a call. (Depends a bit on when you last had your car in an MB dealer as to the validity of your Mobil-life)
Drove the car this afternoon ..came out an hour later to these problems...have checked fob with dig camera and can see ir is working ...do you know what the manual reset procedure is ...I am going to have trouble getting help in the northwest of ireland on a Saturday!!
Left the key in for a couple of hours ...went back and tried the buttons a few times and.............success!! Don't know why but have read elsewhere that leaving the key in the ignition gets it back in sync...bit nervous to go too far until I get a second key...Thanks for your advice guys.
AIB understand your special Mercedes deserves a special insurance policy. We have a refreshing attitude to insuring high performance, modified, imported or classic and vintage cars and deal with the UK’s leading insurers. We offer discounts for length of ownership, where the vehicle is kept overnight and limiting the mileage and can also cater for those clients who need higher mileage and business use.
To obtain a quotation please call the team on 02380 268351 or visit us atAIB Insurance
