99 c200 auto box problems
rob_k
ive just brought a merc c200 on a 99 done 140k to run around. when i was driving home if you selected kick down it would just hold 4k but then it wasnt changing right and now is just stuck in in 2nd!! if the kick down is pressed is revs as if in neutel??
Any ideas guys?
thanks Rob
Hello and welcome Rob.
As BlackC55 above do check the fluid level.
Not sure what you mean is the car now stuck in 2 nd
R
rob_k
thanks guys, how do you check it?
also i mean now when i drive it it sets off in 2nd and doessnt change up! ive no ideas. reverse works though?
This sounds like the conductor plate gone, and well known fault,,not so expensive to fix,,and you can get a good indie to do it for you. Do you have one nearbye
simon winn
oxford
This happened to me in my 2001 cdi E class. I presume the gearboxes work the same and it was the electrics pack within the gearbox....
R
rob_k
seems i might of found the problem. the metal pipe that goes from the oil cooler underneath the radiator has corroded and is leaking. ive purchased a new pipe and will refill the oil.
do you think this could of caused the poblem? i was just thinking it wouldnt be pressurising?
Thats good news,,if your car was built after 09-99 then it will not have a drain plug or dip stick but you can make one as in Parrots DIY post
230K
Belfast
E300TD/1998/3.0 Diesel
Thats good news,,if your car was built after 09-99 then it will not have a drain plug in the torque convertor
Had to edit the correct statement. All 722.6 gearboxes do not have a dipstick as far as i know.
Thanks 230K, that is correct about the drain plug and I have edited. I understood that the dip sticks went at the same time,, The 722.6 box came in 1996 in volume does not anyone have a dip stick on these boxes from 1996
R
rob_k
so would a leak in the pipe cause it to lose pressure and not change gear?
230K
Belfast
I had a 1996 C Class with the 722.6 and it had no dipstick.
Thank you again 230K then I will take that none have them as you said,, funny how one can get a mental block on some things, even though they have been discussed so many times
230K
Belfast
Typing before you think! Don't worry we all do it.
230k
R
rob_k
hi guys dont mean to be rude but ive asked a question and ive got a page about a dipstick. can any one please tell me if a pipe leaking will cause it not to change gear due to loss of pressure and fluid? thanks
230K
Belfast
It is likely that it could cause your problems. How much oil did it lose? Fill with genuine MB automatic oil only is my advice.
A dipstick will cost you nearly £30 or so. An independent MB service man will dip it for you for a small fee or you could make a dipstick as shown on various threads on here. Do a search for dipstick.
Check out this: http://forums.mercedesclub.org.uk/showthread.php?t=36250&highlight=auto+dipstick
and this: http://forums.mercedesclub.org.uk/showthread.php?t=24754&highlight=dipstick
Hope this helps
230K
R
rob_k
  • #17
thanks, its lost most of it ive had it checked but wont drive it now as im worried of running it dry
The question that you ask Rob is not easy,, the fluid leaves the torque converter and goes through the cooler, and the repeats,,I would imagine that the fluid did become too low to circulate .
The first question that you were asked was "have you checked the level"
R
rob_k
  • #19
yes and it was extremely low hence my thoughts that could of caused it, although i have put in 2 litres but it still stays in 2nd, probally leaked out now though.
thanks for everyones help
230K
Belfast
If it is leaking that quick i would guess/hope that low fluid level is causing the problem.
230K
