99 C240 Fuel problem
davew210
I have a 99 C240 saloon.
When the fuel gauge gets to around half way down, I am running out of fuel. It takes around £25-£30 (@ 85.9p per litre) to refill the tank from half way. Is this the normal amount the fuel tank should cost to fill from empty? If it is it shows a fuel gauge problem. If not, any ideas? Any help would be good as the AA are getting a little fed up with helping me out! ;)
jberks
From memory your tank is around 60 litres - so 60 x 90p is £54 to fill up.
So if you're running out and then putting £30 in to fill it, there is something very odd going on.
The gauges senders are known to fail but that doesn't sound like your problem.
Are you saying that the gauge shows 1/2 yet you run out and then when you do fill up, you only get 1/2 tank's worth of fuel in?
If so, I believe the tank may be physically built in 2 parts and one is not working properly - poss a blocked pick up pipe. I dare say Malcolm will have a diagram!
Malcolm - over to you!
Ultymate
N. Wales
C230K Estate 1998
Iain the gadget
Edenbridge, Kent
W208 230CLK W163 ML270cdi
Make sure the tank isn't damaged. If it is compressed in anyway, this could seriously affect your capacity whilst the sender unit could be damaged in such a way that it will be recording the wrong amount of fuel.
D
davew210
Thanks for the replies, the two half tanks would seem to fit the problem. I have not been able to run the tank below half way as I have run out of petrol before then so maybe its only using one tank. Is there a pump that transfers fuel from one side to the other? If so, how do I get to it? Do I have to take the tank off the car?
