99 c250 clattering on start up
Ad777
1999 C250 TD estate W202 engine
Hi all, have had a few months trouble free driving..long may it continue!
When first starting the car in the morning, it always sounds like a bag of nails for about a minute, then settles down for the rest of the day. Is this common?
I am also having an issue with a sticky front wiper blade. Have replaced with a new good quality one, cleaned the glass, but still catches/sticks, even when raining.
Any suggestions appreciated!
CowleyStJames
Oxford
Mercedes-Benz E63s, Old knackered G wagon
Oil changed recently?
Could be timing chain or tensioner.
Both can be changed with engine in car but examine sprockets, and if worn , you'd probably want to change all three sprockets as well.
One sprocket is impossible to do with engine in car, so engine out
A
Ad777
Thanks for that...I have only done 100,000 miles, and it has been well looked after with servicing. Are they prone to going? What type of oil would you suggest? I have just been using motor factor oil last couple of changes, so probably not the best!
mattkh
England
A160 W168 1999 1.6
..... I have just been using motor factor oil last couple of changes,
Which one did you use 5w30 or 5w40?
As regards the wiper, position it away from the screen, turn the wipers ON, and observe the movement. Is it still jerking?
Sticky front wiper blade is as likely as not the mechanism requiring lubrication. It's a clever system the single wiper but it does require lube under the black clam-shell cover
Doug1234
Bedfordshire uk
1997 w210 e300td
Most likely got some air in the fuel lines .
The plastic fuel lines have o rings that can perish and let air in which will cause clatter.
Firstly though just keep the fuel tank at least more than half full as these have saddle tanks and can run out of fuel below half full.
Bad glow plug or two will make hell of a noise until relevant cylinder has warmed up a bit, but normally the glow light comes back on after start up to notify a problem.
ajlsl600
france
Have someone verify its not chain noise .that can get very expensive.go from there.
A
Ad777
I have used 5/30, both times? Just tried the wiper off the scrèen, it is not jerking, but making a loud squeaking noise, which I thought was the rubber on the windscreen!
A
Ad777
Can you advise how to remove black cover, and best lube to use? Looks like the culprit! Ta
A
Ad777
Have had starting issues since got the car..changed all pipes and o rings, injector flexi pipes, o ring in pre filter etc. Keep it 3/4 full...still doesn't start in morning for ages if pointing uphill..so just park nose down! But air still in system for sure . Still got to replace flexi fuel pipe, and gasket behind pre heater? All I can think of. Glow plugs good...could air at initial start up cause that clatter?
A
Ad777
I will certainly investigate, thank you.
Doug1234
Bedfordshire uk
1997 w210 e300td
This is air in fuel clatter
Do check your belt tensioner shock , this video shows it clearer than others .. just press on it with your thumb hard
A
Ad777
It's identical to the first one! Uneven tick over and clatter, then levels of and is quiet and even for the rest of the day. How does air do that..is it something to do with injectors?
You should be able to unclip the bottom of it. There is a guide in the DIY section although the pictures have died :(
A
Ad777
I have just tracked it down, and there was a link in it to one with pictures! Cheers, Appreciated.
Doug1234
Bedfordshire uk
1997 w210 e300td
Injector is only putting half the amount of fuel it should or less in cylinder because of the air bubbles in the fuel and this affects the firing, similar to pinking in a petrol engine
So you still have a minute leak somewhere which either lets fuel leak out or air get in which lets the fuel run back to the tank.
A
Ad777
  • #17
Pinkering is just what it reminded me of.
Thanks for the help and explanation..I will get to the bottom of the air draw one day! Cheers and thanks again.
