Ad777
- Jun 29, 2020
- 1999 C250 TD estate W202 engine
So..I have been plagued with air in system,hard to start parked up hill..I had a quick look today and all the white clips holding pipes in were loose from last time pipes were changed! Seated them all, but then noticed a drip on bottom pipe.
More investigation showed that the leak was coming from top of what I guess is fuel pump? Box lower down rhs of engine, with 5 pipes coming out of top, to injectors?
They are held in place by metal clips screwed down with star head screws.
Has anyone come across this before? Is there seals I can replace, or is it more complicated!
Hoping this might cure air ingress when fixed too...advice appreciated.
