BClassClassSlk
- Mar 15, 2024
- B180 2013 W246
My Car: MERCEDES-BENZ B-CLASS Sports Tourer (W246, W242) B180 (246.242), M270.910 Engine
1.6 Petrol Direct Injection
Mileage 73,000 km (46,000mls)
What happened?
• returned home after 8 months away;
Negative terminal was left on causing car battery to deplete and drain the Starter Battery(A0019828008) and the Auxiliary Battery(A0009829608)
These have been replaced with Brand New MB Batteries from Main Dealer Parts.
I now have the following hard fault codes (*Please ignore - PA06DAA - aware of this issue*) that all seem to link to the Rear End Braking and Traction.
I have no idea what caused this and would like some help if possible.
The car drives - but the EML is now triggered causing the vehicle to drive in Limp Mode due to
C003700
State: Current
The Left Rear Wheel Speed Sensor Has a Malfunction. Please see the following from the OBD Diagnostics:
1) Diagnostics Shows:
ECM - Engine Control Module (MED40) for Combustion Engine ‘M270’ (N3/10)
[FAULT: 2]
PA06DAA
State: Current
The actuation of the Valve of the Oil pump in the combustion engine has an electrical fault or open circuit
C003700
State: Current
TCM - Transmission Control Moduke (CGSFDKG (N15/13))
[FAULT: 1]
D40B00
State: Historic
An implausible Left Rear Wheel Speed Signal was Received
EPB - Electric Parking Brake
[FAULT: 1]
U012100
State: Current and Historic
Communication with ESP Has a Malfunction
ESP - Electronic Stability Program (N3 0/4)
[FAULT: 1]
C04E700
Component L6/3 (Left Rear Axle RPM sensor) is Defective or the Wrong Model is Installed
ESP - Electric Power Steering (N68)
[FAULT: 1]
U041586
Implausible Data we’re received from control unit “Traction System”. There is an incorrect signal
SG - AWF - Control Unit ‘Distance’ Warning Function (A90)
[FAULT: 1]
C326600
State: Historic
Chassis CAN Bus: CAN Signal “Operating Condition” From Control Unit “Electric Stability Program” is Implausible.
2) Dashboard shows: See images attached
IMG_7660.heic
IMG_7661.heic
IMG_7662.heic
I really hope someone can help, as I’m stranded without a vehicle to drive. I’ve seen a video on YouTube
Not sure if this is the same fix though.
All suggestions welcome.
Thank you so much!
What happened?
C003700
State: Current
[FAULT: 2]
PA06DAA
State: Current
C003700
State: Current
[FAULT: 1]
D40B00
State: Historic
[FAULT: 1]
U012100
[FAULT: 1]
C04E700
[FAULT: 1]
U041586
[FAULT: 1]
C326600
State: Historic
IMG_7660.heic
IMG_7661.heic
IMG_7662.heic
Thank you so much!
