A Class Rip Off
pain in the a class
Can Someone Tell Me Who In Mercedes Decided To Combine The Air Flow Meter With The Ecu...knowing Full Well That The Air Flow Meter Is A Very Tempramental Thing..as Ive Decided Myself This Is All To Rip The A Class Driver Off...on A Normal Car The Air Flow Meter Is Separate Costing Between £40 - £50 To Replace And Takes The Mechanicaly Minded Approx 10 - 15 Mins To Change..but Not On The A Class , You Need An Airflow Meter Well You Have To Send Your Ecu Off Because It Is Attached To The Air Flow Meter To Be Repaired At Around £200--£300 Or Go To The Main Dealer And Pay Between £600 - £900 For A Replacement...sorry About The Rant But I Had To Get It Off My Chest ...thanks For Listening.....ps From Reading Other Forums This Seems To Be A Big Problem Maybe Mercedes Should Recall All A Classes To Rectify This Problem..
Sadly we are seing more and more components all being moulded into one making replacment parts very expensive like a flasher unit costing £300 or an ignition switch at £300 up to £1500 for a ABS modulator with built in pump. £650+ when the clock packs up.
Malcolm
