markben
- Feb 12, 2017
- Location
- Bristol UK
- w220 2004 S320L CDI
Greetings all
At 3.30 p.m. today I went to unlock my 2004 W220 (using the Remote control key fob) and nothing happened. Zilch. Locked out . A flat battery in Remote key maybe?
So I tried again with the spare key & new battery. Still nothing . After unlocking the driver’s door mechanically with the detachable ‘blade’ I inserted the key fob into the ignition to start the car. Result: the dashboard display didn’t automatically illuminate as it should, and NO start - just some alarming electrical buzzing noises. Yikes! I’d only ever had a ‘Low Battery’ warning on the dashboard display once, briefly, and several months ago. Mmmm... .
Then.. I tried to unlock the boot (again using the mechanical blade key to over-ride the PSE system). Result: much clicking noise from the PSE pump and the Bl…y Alarm went off. W220s are notoriously complex electrically, and a flat battery could be due to a myriad of other issues. Double Yikes!
So I called my Motor Insurer’s Breakdown & Recovery service for a ‘Home Visit’ (quoted time 90 mins - but thankfully the local agent arrived within 45 mins). After various checks, the technician diagnosed a ‘failing’ 6-year-old battery, gave it a brief Booster charge and confirmed that the Alternator was working ok. His advice: ‘It will start now, get it in for a new battery - but DON’T switch the engine off in between or you’ll be STRANDED again!’. Triple Yikes?
By now it was 4.30 p.m. and getting dark: so I drove in Trepidation to my friendly & helpful local National Tyres & Auto Care centre 10 minutes away in the hope of getting there without breaking down En-route AND that they would have a replacement battery. If not, Halfords (‘Halfrauds’?) were nearby and open until 8.00 p.m. so I decided to take my chances on either or both to keep mobile and avoid further hassle (breaking down / further Recovery services / Taxi fares etc).
15 mins later, NT&AC had a new OE spec 019 battery in stock and fitted it for £140 all-in + with a 5-year Guarantee. This was exactly the same price as the one I’d had fitted 6 years & 40k miles ago. Their conclusion: ‘pretty good performance for a battery - but the latest Cold Snap + increasingly frequent use of ancillaries (headlights, wipers etc) have probably finished-it-off’.
End-to-end from the start of my 'sudden' (or not?) flat battery issue to resolving it took only 2 hours and with no further complications or hassle. All I can say is a big ‘PHEWWW!’
My Conclusion? At this time of year (e.g. in the UK), keep a Close Eye on the health & performance of your car's battery - especially if it's getting older AND with greater demands on it during cold and dark Winter months. Replacing it as a precaution could save you more than the cost in terms of wasted time & hassle if you don't.
MB
'The Best or Nothing'.
MB
