A150 horn not working
Nick64
Newport
A class /2008/150
Fuse looks good. Does it use a relay? Any ideas on location etc.
Thanks All
Have you tested the horn itself i.e. put 12 volts across it
N
Nick64
Newport
A class /2008/150
Not yet. Raining at the moment. Will look at it later.
Is it visible inside the engine bay?
Also what’s the resistance of it?
Sorry, no idea where it is .... wheel arch perhaps. But when ever a car horn has failed the easiest check is whether the horn itself is at fault or the wiring to it.
No need for a resistance check, just apply 12 volts dircectly across the terminals .... doesn't matter about polarity.
N
Nick64
Newport
A class /2008/150
Ok. Will report back
mattkh
England
A160 W168 1999 1.6
Should be.
And in terms of checking the relay, you can just rely on hearing the 'click' when pressing the horn button.
It is most likely to be the horn because of the atmospheric conditions of where they are located.
N
Nick64
Newport
A class /2008/150
N
Nick64
Newport
A class /2008/150
Relays or horns?
Won’t see the car until Saturday now.
ZZZZ
Relays or horns?
Horns. Not sure about relays - bought a full kit to replace the standard ones, but am waiting for the rain to stop, before I get to fit them ... so could be a while - like next decade or so ;)o_O
N
Nick64
Newport
A class /2008/150
I am the proud owner of a girlfriend and as such she does not see rain.
