A160 First Gear Slipping
cadz7
Hi Can Anyone Help Me, My Wife Has An A160 2000 Model With A Triptronic Gearbox. When You Pull Off, First Gear Slips On It, All The Other Gears Are Fine It Just First. It Does This In D And When Using Triptronic. If You Pull Off To Quick It Revs And Goes Into F Mode. It Wont Pull Off On Hills. Fault Code P1886:( :(
hellgrace5
I googled and found this topic.
I am facing the same situation. First gear slipping upon take off.
Any solution ?
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Needs time on star first of all to see whats going, expect an expensive repair bill.
Rule number one when considering the W168 A class mercedes
NEVER BUY THE SEMI AUTOMATIC OR FULL AUTOMATIC A CLASS.
Rule two
Consider a Yaris instead.
jib
hellgrace5
Will bring it to a diagnosis and post up the result and keep update.
Steve@Avantgarde
Bristol/Somerset
I had one doing this 2 weeks ago. The star guided fault finding said to replace the electro hydraulic control unit. Cost new was £1000 from Benz but I had it repaired for around £400 I think. With a new oil and filter and labour I think the repair came to around £750.
hellgrace5
Wow. Expensive repair job :shock:
Yours a similar to mine ? W168 fully automatic ?
Steve@Avantgarde
Bristol/Somerset
It was a A170CDI but they have the same gearboxes.
EHCU repairs/replacements are never cheap Im afraid to say as much as us indies try to keep the cost down they are an expensive piece of kit to fix.
www.W140.co.uk&www.r129.co
